RE: AMR TRAINER 20
Cherokee,
There is a problem with using metal bolts here for the wings. The wings bolts screw into metal T-nuts. If you use a metal bolt you will risk the bolts vibrating loose in flight. The nylon bolts won't vibrate like metal bolts will. The nylon bolts are strong enough to secure the wing to the fuselage.
Ken
