RCU Forums - View Single Post - JetCat Start Problem
Old 06-14-2011 | 03:05 PM
Dave Wilshere
Default RE: JetCat Start Problem
Mark
Stiff pump. I have seen a couple recently than needed a higher voltage to kick the pump going, yes increase the start voltage, maybe to 0.4v.
You can normally feel light warmth and see the burner glowing if you hold your hand across the tube or look from a safe distance. This tells you its no fuel.
Dave
