RCU Forums - View Single Post - JetCat Start Problem
Old 06-14-2011 | 11:30 PM
Dave Wilshere
Default RE: JetCat Start Problem
Mark
Yep, you can check flow in the test. The latest batch of pumps seem to need a higher figure, maybe after some running it will reduce again, but for now fuel needs to be flowing. Some pumps also "stick" between gear teeth and need a higher voltage to kick them loose
Dave
