RE: JetCat Start Problem
Guys, if I use the GSU to test the kerostartvalve then a healthy trickle of fuel flows. Would thisindicate the pump is ok at low voltage or does the pump push more at this point than during the start up?
Last night I was using the kerostartvalve test with the lines still hooked to the turbine to try and prime things. Worked ok but I knew if I overdid things it would get lively!
Btw, where in that JC menu structure do I up the pump start voltage if I need to??
Cheers
Mark
