RCU Forums - View Single Post - Curare 60
Thread: Curare 60
Old 06-15-2011 | 08:02 AM
  #45
mmiller1
My Feedback: (75)
Default RE: Curare 60
R_G and David: I think I might agree with you re: thrust angle. 2 degrees is so slight. Not even sure I could detect it with the eye...so if it looks that obvious it is probably too much. When you mention : datum line are you referring to both a lateral view as well as a top view. This seems to make sense to me. So, if I am initiating a down thrust of 2 degrees, my thinking is I would copy the datum line from a lateral view of the plans onto the fuse and take a reading (protractor I guess) from that...? Is there another way?
Same would hold true for right thrust....?
Tim
