I should probably e-mail Don at Eureka and ask if the FW already is set for 2 degrees of down, but that would have had to be something he added since the plans indicate a 2 degree down set. Does that make sense? If that was the case, perhaps no washers are needed. However, the thrust offset of 3 degrees to the right would then follow suit, I would think. But when I placed the engine (attatched to the mount) on the FW it looked like it was at zero, thus a washer on the left side is called for...or perhaps 2? Actually, I tried 2 and that was way too much..probably more like 5 degrees. I will do some more tinkering and measuring. Thanks again.
Tim
