RCU Forums - View Single Post - Glassing balsa mid-wing
Old 06-15-2011 | 05:13 PM
HighPlains
Default RE: Glassing balsa mid-wing
I think wax paper does a great job because it globally flexible but locally stiff, thus easier to get a smooth surface where you transition from glass to balsa. It is also easier if you use multiple layers of two oz cloth with staggered edges, as the thickness at each edge is thinner. Place the widest layer on first, with the last one the narrowest.
