RCU Forums - View Single Post - JetCat Start Problem
Old 06-16-2011 | 06:59 AM
Carsten Groen's Avatar
Carsten Groen
Default RE: JetCat Start Problem
ORIGINAL: Vincent
I have been running jetcat kero start for over 3years now on all of my motors. A .200 setting is the typical setup direct from jetcat. I have NEVER seen a normal starting motor work below that setting consistantly.
I have/had several running with a Uacclr1 below 0.2, so not uncommon.
Two P60SE, both running at 0.125 (consistantly for more than 100 starts), and a P80SE that runs at 0.150
Most of my P160SX are however at 0.175/0.200
It is always a good idea to run the "drip test" in the JetCat manual!
