RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
nitrohead, I just looked on RCMarket and saw the Knack foam tires. Do they have 12mm hexes?
I also see, under the 1/10 foam tires, a company called Xceed that makes foam tires. They have 26mm and 30mm tires. They also have a few sets marked "wide rear tire" and it says they are for a 220mm car or body. How wide do you think they are and would those fit a 1/10 car with 12mm hexes?
