RCU Forums - View Single Post - what do I call it
Old 06-16-2011 | 01:57 PM
willig10
Default RE: what do I call it
It is really simple to make them yourself. All you need is to buy some hardwood and use a dremel with a tile cutter tool and cut to depth and length as required for your application. A lot cheaper as well. Then use the nylon brackets to attach the gear as usual.
I usually after cutting the blocks to fit, install the 2 gear wires and then use 5 or 15 minute epoxy and place that around the landing gear.
Glenn Williams
