ORIGINAL: huck1199
Set your throttle failsafe to 'off' on your TX. You should allways turn off RX first.
You will have to re-bind the RX to the TX to do this, make shore that the throttle stick is all the way back, this is how you set the failsafe with Spektrum.
Cheers
