ORIGINAL: knucklebutt
Bob
Most needle valves now have a ''set screw'' in them to add an extension. Sometimes on the end of that extension I will add a very small wheel collar or just an ''L'' bend
I can provide photos if you need them
Denis
Thanks, Knucklebuck. I already have an extension from the needle valve, but it isn't long enough to reach the hole I drilled into the top of the cowling. Yes could you provide the photos? What I would like to do is make an access panel in the cowl to be able to get to the needle valve as well as the carb and fuel line if I need to cut the fuel flow.
