it's only the side to side
Everything is tight except for the lateral movement of the pushrod in the center of the plane when you wiggle one of the elevator halves by hand. There is no hinge gap, the horns are good, the servo arm is good, etc.
Will air movement during flight equalize the pressures on both elevator halves such that this side to side won't be a problem?
