ORIGINAL: Carsten Groen
ORIGINAL: BaldEagel
I don't think these motors where ever designed to run on 0.2volts, I think they where designed to run on 6volts, perhaps a software upgrade to kick start the motor and then reduce the voltage is required, just a thought.
Mike
Sure thats not already the case ? I _think_ that when starting, you hear a very short burst of the pump, like it has a much higher voltage for a very short amount of time ?
I might be wrong though...
