RCU Forums - View Single Post - Convert flat pack to square
Old 06-17-2011 | 04:15 PM
SeaJay
Default RE: Convert flat pack to square
JD,
Typically, the batteries in a pack are glued together, and then the way the tabs are welded together, would make it a bit difficult to make the switch. it can be done, but you would have to cut a tab between the center two cells, then take the two packs of two cells, glue them side by side to make the square shape, then you would have to solder a jumper where you cut the tab.
Can it be done? Yes..
is it safe? If =done correctly, yes.
is it worth it??  IMHO Nope!!
Craig.
<br type="_moz"/>
