RE: trying to adjust flaps
Try a little at a time. What happens is that if you use too much and you need to steer with ailerons the upward moving aileron dumps the lift and the wing stalls.
5 degrees maybe for starters.
I'm not familiar with that design but if they are wing tip ailerons don't do it, if they are full wing span ailerons you can get away with a little.
