RCU Forums - View Single Post - Neptune ARF advice on 1st seaplane? Construction tips?
Old 06-18-2011 | 06:27 AM
  #51
terry.mortimore
Default RE: Neptune ARF advice on 1st seaplane? Construction tips?
ORIGINAL: lupy
Terry, your stab incidence must have been way off, again, strange quality problems. Glad you didn't lose it to the cap blowing off. What scorpion motor did you use? Any damage in the splash down? I built a little tray to hold my battery up off the hull. I had a battery break through the bottom once on a badly bounced takeoff with my old seamaster.
Hi Lupy: I sent a note to Lucien at innov8tive designs and I'll include his reply at the end of this note. I'm pleased with the power package that I have and it flies the plane nicely. I have my timer set at 10 minutes, but I've had some 12 minute flights. I'm using a 4 cell 4200 mah battery. The splashdown did remarkably little damage, she was flying two days later. If it had hit solid ground it would have destroyed the plane. I have a slide in tray mounted to the bulkheads that I access through the front hatch and this has worked well.
This is Luciens reply:
There are several ways you can go with a plane like this. The Uranus 35425 motor that they call out in the ad looks to be based on a 28x20mm stator judging by the size of the motor, and has a Kv value of 1,100 RPM/Volt. Scorpion has their SII-3020-1100 motor, which is a similar size and weight, as well as Kv value. Running on 3 Li-Po cells with an APC 11x7E prop, you would get the following performance numbers from this combination.
Amps – 51
Watts – 566
RPM - 10,000
Thrust – 72 ounces
Pitch Speed – 66 MPH
This is decent power, but not great. This gets you a little under 100 watts per pound, with will fly a seaplane, but does not give enough power to really jump off the water. About 125 watts per pound is a good place to be, and for a 6 pound model, this would require 750 watts of power. Running on 3 Li-Po cells, to get 750 watts you have to pull 68 amps of current, which is kind of high for a 3-cell pack. If you go with a 4-cell set-up, then for 750 watts you need about 51 amps of current, which is a bit more reasonable.
For this much power, the Scorpion SII-3026-890 motor is the best choice for use on a 4-cell battery. With an APC 11x5.5E prop, this combination will yield the following performance numbers.
Amps – 50.1
Watts – 742
RPM – 11,900
Thrust – 98 ounces
Pitch Speed – 62 MPH
This is just about exactly what you need for great performance with this size plane. You can also run an 11x7E prop if you want to go a bit faster That set-up would get you these performance numbers.
Amps – 57.1
Watts – 845
RPM – 11,600
Thrust – 98 ounces
Pitch Speed – 77 MPH
With this set-up, you get the same amount of thrust, but get 15 more MPH with a 7 amp increase in current draw.
I would recommend using a 4-cell Li-Po battery with a capacity of around 3800 to 4200mah and a 70 amp or larger speed controller.
Lucien Miller
Innov8tive Designs, Inc.
1495 Poinsettia Avenue, Suite 144
Vista, CA 92081
