RE: Perry Carb question..
I don't understand the meaning of top and bottom here. The larger number is the outer diameter of the base and smaller number is the bore of the carb barrel. The two engines then use the same bore in the carb which is not that strange when they are quite close in engine size anyway. The difference of the base diameter is just so that it fits the case, and has no influence on fuel draw or anything.
