RCU Forums - View Single Post - Perry Carb question..
Old 06-19-2011 | 04:20 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Perry Carb question..
ORIGINAL: jaka
Hi!
If you have 13mm neck diameter on your engine , MVVS has several carbs (7mm, 8mm, 9mm, or 10mm. I can custom make any size between those if you like).
Unfortunately, the O.D of the carb neck on these K&B's is 15.8mm. The venturi is in fact 8.5mm. I'd probably use the same size venturi, but I'd want better adjustability of the idle/midrange mixture than I do with the current carb. If I had the ability to machine small parts, I'd just make a new mixture disc and just move the spraybar orifice a little bit to have better adjustability of the midrange.
