RCU Forums - View Single Post - Repairing a Jetcat ECU
Old 06-19-2011 | 06:54 AM
Moerig
Default RE: Repairing a Jetcat ECU
ORIGINAL: Peter Nir
Checked my second ECU and all of the continuity \ resistance checks i made are the same. i am puzzled. [:@]
Just replace the fett. Sometimes with a blown fett some real small solder balls ooze out under the epoxy case, sure indication of a failed die. Any 30V plus 30A logic level fett will do. Dont listen to the doomsayers, its an easy fix, not rocket science.
