RCU Forums - View Single Post - Mick Reeves Hunter
Old 06-19-2011 | 01:30 PM
  #102
dabevan's Avatar
dabevan
Default RE: Mick Reeves Hunter
Turning my attention to the ECU and other engine related stuff, I decided I wanted to make it as easy as possible to transfer the turbine to other airframes and so have mounted everything engine related on one ply plate.
Changing engine should be a case of unbolting the turbine, unscrewing the ply plate and disconnecting fuel and turbine power - everything else should be self contained.
ID:	1625374   Click image for larger version
ID:	1625375   Click image for larger version
ID:	1625376   Click image for larger version
ID:	1625377   Click image for larger version
