RE: Modifying main gun fire control
Take the back off of you TX and wire in a push button to the circuit board containing the connections off the trim pots. You'll wanna wire/solder into the neutral position and the trim up postion wires on the circuit board. Then you can drill a hole and postion the button on the back or shoulder of the TX.
Hope this helps.
