RE: edelbrook 600 bog
If you're not getting a pump shot with minimal deflection, your pump is probably dried out or cracked. Also, if it's an older one, it might not be impervious to the ethanol in the fuel, causing it (and other stuff in your fuel system!) to deteriorate.
Is it the Quadrajet replacement, or the Carter type?
