this is my project for the summer. a Castle Creations Mamba 6800kV powered 2nd Gen Xmod. this motor was just sitting around in my room gethering dust so i decided to make something.
this pic is of the mount that would house the motor: This was where i had to trim plastic away from the mount so the motor would rest level to the chassis.
the mount again, side view:
This is the mount with differential and spur gear with rear suspension mounts:
again with motor spacer:
motor at rest in mount without strap:
again with gears meshing:
Motor in mount with strap: this part was tricky, trying to get the strap to fit around the motor i ended up using some longer screws and having a space between the strap and the chassis:
again front view:
next was the most difficult along with the bugs with servo centering. i had to convert a 5-wire servo into a 3-wire plug. this was done using an airplane servo:
i took it apart and looked at the circut board. it converted 5 wires to 3 so i unsoldered the 5 wires from the pot and the motor inside the servo:
i slipped the board down inbetween the slot where the AWD Drive shaft would normally sit and soldered the wires according:
Servo Board Stock Servo
black white
white orange
red black
Motor Stock Servo Motor
black red
white black
Here is the whole car minus the esc and battery wired: i had a problem with the tires rubbing on the bottom of the motor, this was solved by longer screws and the hardest type of truck springs i could find.
whole car not wired:
car completed (messy):
heres a vid of the tire shredding apart:
http://www.youtube.com/watch?v=2szRNs1vRdg
can anyone help me with the issue of the servo not centering? the servo was a Tactic nano from a cessna.
http://www.youtube.com/watch?v=H_AqB00LNDM
smokin the tires:
http://www.youtube.com/watch?v=Mil3BfUbkQw
im also trying to find a way to use the stock wire antenna instead of using the soft wire that comes on the receiver.
i may have found a way for the steering to center. using the pot from the tactic servo i used. i drilled out the sway arm from the old pot to fit the shaft on the new pot, i had to trim the shaft down about quarter inch to make it fit.
IT RUNS COMPLETELY PERFECTLY!!! HOLY **** I GOT THE STEERING TO CENTER!! YESSSSSS!!!!!!
http://www.youtube.com/watch?v=_aO8q770CoM
i now own possibly the fastest xmod ever.
heres a pic of the car with my Saleen body:
The 1st test (ever) will be a speed test on 4 Energizer Ultimate Lithium cells. (9 effing bucks for 1 pack Dx) theyve shown a significant boost in power and speed vs alkalines. The body will be ON to help with aerodynamics and reduce drag. I have never driven this car outside because i dont live on a smooth road. So ill head out to the tennis courts soon.
