RE: Extreme Flight 88
Have flown my new Yak for the past 3-4 weekends and noticed that my wingtube is not a tight fit thru fuse and also the supplied wingbolts lack maybe 3/16" to 1/4" of being fully threaded to the shoulder, which after a couple of days flying sent me to Lowes to pickup some thick rubber washers to make sure I wasnt bottoming out when I assembled the plane I also reinforced the fuse tube with some gorilla glue. I probably will wrap with blenderm or something to tighten wing tube itself where it goes thru fuse. I like to do vertical snaps to KE spin (still learning) and 1 1/2 snaps (also learning) and want to make sure everything stays put, believe me-I dumb thumb enough without having a plane come apart in the air.
