RE: DA100-Spitting problem-Is this normal???
I have a BME 115 that i got from Keith Baker. I was told is was an engine from the 2nd group of engines , it is about 4 or 5 years old. It is a littel drippy at the carb at idle.
I got the carb block fix from the nre guys at BME afew years ago.I also put a 90 deg snokel from 3W that helped some I think it just hold the fuel till the engine sucks it back on.
Do you think the reeds should be replaced. I have the carb set low end as low as I can to keep the engine running from low to high speed with no lag. I have a rebuild kit for the carb I will try that now.
Thanks for the help MB
