RCU Forums - View Single Post - header on backwards
Old 06-22-2011 | 06:15 AM
proanti1's Avatar
proanti1
Default RE: header on backwards
ORIGINAL: DaveG55
Two things;
1 - If you are running so rich that you have unburnt fuel, as opposed to unburnt oil, then you're not ''a little'' rich, you're way rich. Being too rich is as bad for one of these engines as too lean. If you wanna run rich, fine, but raw fuel in the exhaust means you are more than a little lean.
And, yes, allowing raw fuel to sit in the engine can be bad for the engine.
2 - If you add length to the exhaust you will alter the back pressure in the pipe and, at a minimum, alter the power band and could seriously affect the power the engine produces.
I think you misunderstood him. He is just tired of the exhaust blowing oil all down the side of his body. These engines do blow a lot of unburnt fuel out through the exhaust though, its carried along with the oil.
He is probably running the stock HPI motor with the stock pipe, and if that is the case, the powerband is probably not all that great to begin with. Adding a little header length will not effect it that much, it may take a little off the bottom end... but barely enough to notice.
