RCU Forums - View Single Post - What tools/parts do I need?
Old 06-22-2011 | 07:12 PM
davidgeorge212's Avatar
davidgeorge212
Default RE: What tools/parts do I need?
Alot of the time, kits like these have manuals you can flip through that list the basic tools you will need to build this particular kit. Looking at the manual for this kit says you will need these things:
Thin and Medium CA
30 Minute epoxy
xacto knife with a pack of #11 blades
a zona saw with a good blade on it
T-pins
wax paper
masking tape
some kind of drill for drilling holes: You will also need these sizes in drill bits: 1/16", 5/64" (or #47), 3/32", 1/8", 5/32", 3/16", #10 (or 13/64"), 15/64" (or 7/32"),1/4", 17/64"
Pliers
Scissors
Straightedge
String
Masking tape
Screwdrivers (Phillips and Flat Blade)
And a Bar sander
The manual I am getting this information from is located here (on page 5):
http://manuals.hobbico.com/gpm/gpma0...anual-v1_2.pdf
These are just a lot of the basic things youll need to complete a kit like this. If you decide to build more kits, you will be for the most part set to go because these tools are things that you can use for almost any build.
