Thanks Jeff
I will give a 14x10 a try, bench test says more RPM, Less Pull and max watts and amps (longer flights??) I will have to try it in the sky
<colgroup><col width="155" style="WIDTH: 116pt; mso-width-source: userset; mso-width-alt: 5668"></col><col width="191" style="WIDTH: 143pt; mso-width-source: userset; mso-width-alt: 6985"></col></colgroup>8 cell | 14x10 APCe |
max watts | 868 |
max volt | 29.44 |
max amps | 29.24 |
Pull in lbs and oz | 7 lb 0 oz |
rpm using a dvt | 8550 |
8 cell | 15x10 APCe |
max watts | 1142 |
max volt | 28.97 |
max amps | 39.08 |
Pull in lbs and oz | 8 lb 3 oz |
rpm using a dvt | 8070 |
8 cell | 16x8 Xoar |
max watts | 1320 |
max volt | 28.5 |
max amps | 44.69 |
Pull in lbs and oz | 10 lbs 5 oz |
rpm using a dvt | 8000 |
