TIGER I LATE VERSION "WITTMANN"
NEW TIGER I AIRBRUSH LATE-VERSION METAL EDITION "WITTMANN EDITION"
with the new metal lower hull !!
You can open the hull in 3 seconds ! Thanks to a brilliant closing/opening system...
TRACK TENSIONERS
3:1 METAL GEARBOXES
The new gearboxes have one more gear (3/1)
And are equipped with stronger engines (18000 u / min)
All the gears are in brass bushings stored
The drive axle is equipped with ball bearings
THE NEW LATE PROD. METAL TRACKS
COMPLETELY CLOSED TRACK LINKS
THE BEST TANK WE CAN OFFER !!
METAL TRACKS (WITH CORRECT CHEVERON TREADS),
SMOKE SYSTEM, SOUND SYSTEM, HIGH TORQUE MOTORS,
METAL SPROCKETS / IDLER WHEELS, METAL ROAD WHEELS,
METAL REINFORCED SUSPENSION MOUNTING POINTS, METAL, SUSPENSION ARMS,
BRASS SUSPENSION PIVOTS, METAL SPROCKET ARMOUR PLATES, METAL TURRET,
METAL HEADLIGHT, METAL SPARE TRACKS ON THE TURRET, METAL SCHACKLES,
and many more metal pieces...
with ZIMMERIT !!!!! hand painted!!
AIR BRUSHED PAINTED NEW exclusif color release
WITH ZIMMERIT
METAL OPENING DRIVER/MACHINE GUNNER HATCHES
METAL SPROCKET + IDLER WHEELS
METAL TRACKS ( LATE EDITION)
METAL ROAD WHEELS
Metal Sprocket Hubs
Metal loader’s hatch
LED MACHINE GUN
METAL HATCHES (2pcs)
METAL SHACKLES (4pcs)
METAL TURRET VENTS (3pcs)
METAL SPARE TRACK LINKS AND HOLDERS ON THE TURRET
SMOKE SYSTEM
METAL GEARBOXES 3:1 LATE VERSION
SIMULATED. RECOIL ACTION
FULL INDEPENDENT SUSPENSION ( new system with torsion arms!!)
HI-TORQUE MOTORS
MACHINE GUN SOUNDS
METAL BOSCH HEADLIGHT
HAND PAINTED PANZER COMMANDER
METAL GRILLS ENGINE COVERS (4pcs)
METAL REINFORCEMENT ON THE FRONT (2pcs)
METAL COMMANDERS TURRET
START/RUN/SHUT DOWN SOUNDS
WORKING HEADLIGHTS
METAL AIR INTAKE (CORRECT SHAPE
This is my first Tiger I
I hope you guys Like it it cames with all extras its fenomenal
