RE: Modeltech Magic V2.0 ARF
i Have a new in box Dragon Lady. I just bought it this spring from Coyotee Hobbies in Oregon City Oregon. They are no longer produced. I may be willing to part with it if you are still interested.
Also, I put a steerable tailwheel on my Magic. The skid just doesn't cut it. This was an easy mod. Just drill a hole through the fuselage from the bottom up through the horizontal right at the rudder hinge line. run a wire up through the hole and bend a 90 in it and attach it to the bottom of the rudder. I used a yellow throttle wire tube and glued it to the bottom of the rudder after sliding it on the wire. Then just bend your desired angle in the wire below the fuselage and install a small wheel. Its simple and it sure is nice havign a steerable tailwheel on the magic.
