RE: K 80 programing help
I ran down to the Office to deliver and airplane so I got theparameters for you it is for a K80F
<u>START</u>
Pump Start Point- Auto+2
Pump start ramp- 002
Glow Plug Power- 7.0V
Low Batt Volts- 7.0V
Start Power at Ignition- 120
Fuel Pump Power- 140
RPM 100% starter power- 25.000 RPM
RPM off starter- 22,000 RPM
RPM to reconnect starter- 20,000 RPM
RPM Ignition K.- 3,000 RPM
Pump PW ignit K- 025
engine min flow- 50%
EGT end Preheat- 120C
RPM pre heat K- 5,000 RPM
RPM Fuel Ramp K- 10,000 RPM
Pre Heat Fuel- 045
Ignition Time out- 27.5 S
Start Mode- Auto Kero
<u>RUN
</u>
Full Power Speed- 145,000 RPM
Idle Sped- 45,000 RPM
Stop Speed- 30,000 RPM
Start Min/ Temp- 100C
Max Temp- 800C
Accel Delay- 6
Deccel Delay-4
Stability Delay-100
Pemp Limit- 0248
<br type="_moz" />
