RE: Fuel mixing advice
Thanks Downunder. Acetone definately helps to improve the idle. How you noticed an increased amount of smoke when running FAI fuel? Today I tried some 10% nitro with asynthetic/castor blend again and there was a lot less smoke (plus it smelledmuch better). Is it the oil/amount oilcausing the smoke or is it the lack of nitro?
TCraft, did you ever find your prop?
