RE: Servo speed specs - what do they mean?
Thanks for the replies. Just wanted to know that, as I´m using 2-cell 3000 mAh LiPos with a 10 amp regulator. I can select anything between 5.2V and 7.0V. Since I want to get the 6 volt servo performance of a manufacturer I set my LiPo regulator above 6 volts - actually 6.6 V. This 6.6 volt should be same as a fresh fully charged 5-cell NiMh pack. And reg makes sure that there is no voltage drop when the servos are under the load because my batt pack has more than 8 volts.....
Thanks and regards,
Klarm Yai
