RCU Forums - View Single Post - DLE 20cc
Thread: DLE 20cc
Old 06-27-2011 | 05:58 AM
TimBle
Default RE: DLE 20cc
ORIGINAL: Bernard Groenewald
Hi guys
What do you think of putting the DLE 20cc in the Seagull 540 Edge 60-90 ARTF.Will this engine have enough power?
Bernard,
I beleive the Black Horse Edge 540 .60-.75 is similar to the Seagullplane you have.
the DLE20 is too large for the BH version because the engine needs to be mounted with the prophub 115mm from the firewall. the DLE is 135mm long...
Clive McInnes of CMC hobbies will have the NGH 17cc shortly. Its shorter then the DLE because its carb is in front al glow style and will fit the Edge. Its not much lighter than the DLE but my BH needs a bit of nose weight even with a OS 91FX on the nose. With a 2stroke glow these ARF's need the battery as far forward as possible. the NGH may be the ticket.
