RE: Pattern Practice
We actually added that exact feature last year in G5.5 (a free update for G5 users). At that same time we added other RC features like Aero Tow and Bungee launch, a timer gadget such as you might use on your radio at the field, improved wind/turbulence and thermals, and a simulated heli tail rotor flight failure.
To turn on the sky grid, from the main RealFlight menu select View->Effects and put a check mark next to Sky Grid. To change the look of the sky grid, simply edit the airport and modify the Sky Grid property. A number of different choices are available.
I hope this helps!
