RCU Forums - View Single Post - Which side of the lining?
Old 08-16-2003 | 06:42 AM
elmote
Default clutch
JBW is epoxy with some metal in it. Use it. Very thin layer on the smooth side. Rough side to shoe. Did you wrap 2 turns of elect tape around the shoe and use it to press the lining? leave it 5 mins. then pull it, turn 90 deg and push it back in. Should be very snug but not hard. leve to dry 15 min. Pull shou out and remove tape. look for any excess glue that has pushed out onto the bell surfaces and cut/dremel it away. Shoe should fit well with possibly a little drag at first. Just hhold the head, engine shold still run. Clutch will wear in.
Elmo Te
