RE: Classic TOC Laser 200 build!!
FINALLY!!!! After a bit of a delay, my spruce order arrived on Friday and it was time to get back to building.
First up was the stabilizers. It only took about 1 hour to get the 3 of them built. They are mostly built out of 3/8" square balsa, with one piece of 3/8" square spruce for the trailing edges and a couple of 3/8" spruce for the tail wire braces.
Next is the fuselage. The main "box" structure is built-up out of 1/4" square spruce. The turtledeck formers are 1/8" ply with 1/4" square balsa stringers. 3/16" balsa is then added to the sides of the fuse to give it it's shape.
I am having problems getting pictures down loaded. I will keep trying though.
