Is the carb mounted high up on the back of the engines on the
.80's ? It's starting to sound like a fuel problem to me.
If the carb is way below the tank in the inverted position, that
darned "gravity" might be causing the rich condition....
Most four strokes have the carb mounted directly behind the
crankcase.....and which way you mount the engine doesn't
seem to matter....
