RCU Forums - View Single Post - GP Aeromaster Kit Build
Old 06-28-2011 | 06:35 AM
  #32
Bax
Default RE: GP Aeromaster Kit Build
For AILERONS in a swept wing, you are correct. You want the pushrod at 90-degrees to the hinge line. That makes things go together without any twisting of the aileron horn. Now, if you use a ball link at the control horn and/or servo, then you get rid of the twisting action. In all cases, simplest is best, and a direct pushrod with no angles or bends is always the best way to go.
