RE: Silver Swallow Pulldown
I don't know if you can successfully make a piston out of timber, however towards the end of WW2 in the Pacific, the Japanese were reduced to trying to replace Aircraft engine ball bearings with oil impregnated hardwood solid bearings which sort of worked. The idea isn't as looney as it seems because the shaft bearings in ships were similarly made right up to the modern era.
Ray
