ORIGINAL: LesUyeda
You want to ensure that the air exit area is larger than the inlet, so that you do not ''pack'' air in the cavity. Exit larger than inlet will cuase a negative pressure at the inlet and ''suck'' air into the engine cavity.
Les
To expand on this, the exit area should be at least twice the size of the inlet.
