RE: Sun Dot Help
Arch, You may want to build a little anchor on one of the feet. I found the biggest problem with something designed for indoors was the wind. When you put someting the size of a stop sign on top, it gets a little tipsy. If you use someting smaller on top, just shifting you stance will take you out of the shadow. Make sure you can raise the sun blocker to at least 7 feet.
Steve
