RE: Silver Swallow Pulldown
I was a bit surprised that crank fitted in,,,,,,,, its much bigger and Ive got the cyl honed with a pretty steep taper , that maybe bad,,,,,, and I was thinking of a longer rod ( about 8mm ) to reduce the piston acceleration I will use a Viton O ring in cast contra piston,
