RCU Forums - View Single Post - Flying wing
Thread: Flying wing
Old 07-01-2011 | 08:25 PM
BMatthews's Avatar
BMatthews
Default RE: Flying wing
Pathous, if you're in the ball park now you should be able to use the dual rate setting on the elevator to reduce the elevator portion of the mix while keeping the aileron amount the same or even make it more by using more throw. Then use the dual rate function to reduce the elevator until the roll and pitch are more harmonized.
