Johnny, Iwas proceedingwith the top hinged aerilons since that is what the designer intended and I did not have enough experience to change them. Like you said, Ihad them upside down, and being top hinged the gap is on the bottom and unless you are laying on the ground looking up, the large gap is not visible. Note that I shortened the aerilons by one rib and moved the servo out a rib, respectively. I think they are going to be plenty longenough going with aerilons on both wings, and this will also strengthen the wing center/where attached to the fuse.
Well, it took a little contemplation and trepidation to cut the aerilons out of a wing that you just spent a week of evenings building, but Itook the knife and saw to it eventually:
