RCU Forums - View Single Post - DLE 55 Issues
Old 07-03-2011 | 12:27 PM
futura127
My Feedback: (57)
Default RE: DLE 55 Issues
All I run is NGK plugs. I through away the DLE upon receipt of them. I will pull the tank out again and check. I am using a three line system but the one line is just for filling. Everything was assembled new but I am guessing it is possible that the pickup line came off again within the tank.; I have never had these problems before with the nitro lines ever. I guess if it is off this time I need to wire it on. This sucks because just as I am putting this plane through my paces it starts. Hope that this is all that it is. I may check the needle setting too against what they should be from the factory but it does run good for the first 5-7 minutes.
Joe
