RCU Forums - View Single Post - Understanding Electronics Better...
Old 07-03-2011 | 09:28 PM
mkruse
Default Understanding Electronics Better...
Ok, before you guys tell me to go look through the forums and find the answers to my questions, I already have basically, I am just trying to make sure that how I am understanding everything is correct.
First off, I am looking for a brushless motor for my slow stick I have, I am not going to ask what motor you guys suggest for it, I am going to try and find a motor myself so I dont rely on others for everything and I can be more knowledgeable in this area of the hobby.
I get that the numbers like 2206 (fictional number , not from anywhere) is the size of the can or the size of the stator or shaft?
Secondly, the K/V rating is rpms per volt, and as I think I understand this, the lower the kv the more torque but slower the motor bigger prop is needed. which is better for a slow flyer. The higher the kv, the faster the motor but less torque so a smaller prop is needed but the motor will be better suited for a faster application.
Thirdly, Right now i have a 25a brushless speed control that I have had when I bought a helicopter a while ago and would like to use that esc to save a little money, its an align programable one. So my question is do I look for an esc that will match the max constain amp draw or the max burst draw of the motor or do I calculate what power I am using with what prop I will be applying to the airplane I choose to fly.
I am sorry for the begginer questions and I am sorry if this annoys anybody due to the frequency of this topic but try not to be to mean as I did do a lot of research but not everything I read is understandable from my standpoint and I could just use a little guidance. Thanks for reading.<br type="_moz" />
