RCU Forums - View Single Post - Getting a Tempest Ready For Silver
Old 07-04-2011 | 03:03 PM
Iron Dog's Avatar
Iron Dog
Default RE: Getting a Tempest Ready For Silver
ORIGINAL: pjakew
Also what servos do you silver folks rec for the control surfaces?
This is an area of controversy. Many have run standard servos for years, and state they've never had a problem. Others state anything less than top/near-top of the line is a failure waiting to happen. In my opinion: standard servos are fine for Bronze; Higher-quality servos are a morejustifiable investmentfor Gold; but a good medium-quality ball-bearing servo will serve you well in Silver.
After a couple of unexplaned failures when usingstandard servos, I have gone the digital route, but still try to keep it reasonably inexpensive. The JR DS821 is a decent quality, readily available servo, for about $30 each,that would likely do well for you all-around. However, I also received a bunch of JRDS537 servos in some flight packs I bought a few years ago. Beings these have a little lower torque than the 821s, I use them in lieu of 821s for individual aileron servos. For the rudder, where I think a little more holding power is adventageous, I definitely use the DS821. Beings the elevator is likely undergoing the most strain (and I have lost my elevator control in a turn and found a stripped gear after the crash), I have begun to invest a little more for this servo. For elevator control, I am currently using an Airtronics 94162 digital high-torque, ball bearing, metal gear servo that comes out-of-the-box with a heavy duty control arm. These are available through Hobby People.
The picture below shows my current rudder and elevator setup forthe "Trinity-build" P-51 project I am currently working on.
And "YES" Skids, I DO realize that my servos are not actually screwed-in, nor are my linkages actually connected. Like my fuel tank, this is just a trial-fit.
(I just know you'd find a way to tease me about this, if I didn't "nip it in the bud", first. )
As you can see, I also prefer using carbon fiber rods toensure free-moving, yetflex-free linkages, withoutall the hassle of more carefully laying out an extensive internalbracing structure.
