ORIGINAL: futura127
http://www.mcmaster.com/#=d11g7o
Glow engines must use their mixture for ignition timing. They need fat running for that reason. Gasoline on ignition of course is a different matter.
Now, run glow fuel in a GLOW Carbed engine set-up with CDI and you will find out quickly how much glow fuel you have been wasting.
Anyway, to the original poster and to anyone else wanting gas fuel lines that simply work, use ester based polyurethane tubing. McMaster Carr carries ester PolyU (Tygothane) for 30 cents a foot. It is designed for organic solvent materials like diesel or gasoline. Stays flexible and strong inside the tank or out and doesn't swell. I've been using it with both pump gas and Avgas 100LL. BTW- there is ether based PolyU also which is no good for gasoline....don't get that
Is this the one you use? I have an account so I can order this with no problem.
Joe
Get this one 5549K44
!/8 x 1/32", firm, but thin walled so it's flexible, but not floppy. It is clear and I can't find it in colors....would have liked red or blue translucent.
If you intend to use it inside the tank, straighten the coil first. Use a monokote heat gun.
